Hello,
I have a problem with my dishwasher machine. It is a Whirlpool GU1108XTLB0.
The problem is that it works only the china crystal program. All other
programs do not work if I press the buttons and even the buttons lights
do not come on. Moreover, when I use the china crystal program, sometimes
it stop working before the program ends and the cancel and the program
lightes blinks. Sometimes it finish the program but after a while it
stars the program again.
Any clue?
Most likely the problem is a bad keypad assembly which is a part of the console, but there is a small chance for the control board to be bad as well. I would replace the console first. If you need the correct part number for the console, post the color of it.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503927
You could improve your odds of getting the correct part by checking the keypad/console with a meter. If it checks out OK then it is more likely to be the control board that is the problem.
Here is the tech sheet with info on checking the keypad
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
You could also try the following though it is a long shot as sounds like you have a large number of keys that are not working.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
