whirlpool double oven control panel DEAD!
I had both ovens going the other day. After ending the bake cycles, the panel just went dead! Black! If I open the oven doors, the lights turn on. If I push the start button I get a dit daaaa dit dit dit sound. But other than that, no action. I turned off the breaker box to try to "reboot" it, but no go. Nothing. I hope there is something easy to fix that I am overlooking. I’ve never had problems with my ovens before! Thanks in advance for any help.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RBD306PDT14
Here is the tech sheet
And a manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Could be the control board transformer thermal fuse is blown, see page 3-2 in the manual.
Unplug the unit and check it with a meter.
If OK
Check the transformer windings
Note that is always safer to try and find the fault with the power off as 240 volts is lethal.
If OK
Check that the transformer is getting power should be 120 volts on the primary. Check that the voltage suppressor is OK.
Check that the transformers secondary is putting out voltage, I beleive it is 24 volts AC.
I have the Whirlpool Double Oven and the control panel went out after 4 or 5 years. It has now gone out again. And it’s not cheap!! Can’t believe it. Must a design flaw in this model cause others have reported the same thing.
Rafasan
Are you sure it is the control board or has it blown the thermal fuse that kills power to the board?
yes, I checked the fuse and it’s fine.
Mine did this before. Left the power off for a while and when power came back on it was fine. It has been 2 years since then and it just went out again. Same issues, light works, beeps when you touch buttons. I will try leaving power off for an hour like before.
I have had the same problem with my oven shutting down, then coming back to life for no reason. I just noticed this week that it has been back up for the past week and the only thing I can think of that has changed is the humidity has been high for the past week. It is still lit up as I write this and this has not happened for longer than a day or two for the past year. I will be checking on this for a while to see if it is the humidity that is affecting this, and if so, will be doing something to make the humidity high around the oven.
WE were cooking same thing happened as you, we get no oven light, no codes or sound?
:confused:
