Whirlpool double wall oven
Our oven went dead after while using it. The panel, lights everything is dead. The breaker didn’t trip either.
Any ideas?
Thank you,
DeeDee
I cannot find any info on this unit using the given model number.
Please check it.
First I would check the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next I would check to see if it has a thermal fuse for power to the control board power supply.
This will be a torpedo shaped device in one of the wires close to the control board.
I cannot say if your unit uses this without a model number that I can look up.
If it has one check it with a meter, should be 0 ohms.
Sorry,
The model number is
RBD305PDQ2
Thank you,
DeeDee
http://www.appliancepartspros.com/parts-for-whirlpool-rbd305pdq2.html
There is a thermal fuse in this unit that kills power to the control board etc. (upper left corner of wiring diagram).
If the power is OK then check it.
With the power off to the unit it should be 0 ohms.
It is shown in section 06 towards the bottom of the list (oven thermal fuse).
It will be in one of the wires close to the control board.
If you click on a part’s picture or description a new page will open with more info about it.
If it ios blown replace it then check that the oven temperature and oven fan work OK as they may have caused it to blow.
