Our Whirlpool dryer is not drying, there is no production of heat.
Is there a component that I need to replace?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LTE6234DQ4
Here is the wiring diagram
[https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf](http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208546674.pdf"]http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208546674.pdf[/URL]
Here is a manual which may be close to yours
[URL="https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d322131b309497a852571ca006ce7d2/$FILE/L-56_4314124A.pdf)
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If power is OK
Then next check the heater for resistance with a meter.
If OK then the heater’s thermal fuse.
If this is open get back to us as there are other things that should be checked to find out why it blew.
