I have a Gas Whirlpool dryer. Yesterday it just stopped running. Seemed like it got no power to the buttons to push or anything. I unplugged it overnight and plugged back in this morning. I heard it click and was able to start a load. Within a minute it cut off like I had opened the door. It was blinking 34 (But I think that was just the time left on it). When I felt the clothes they were obviously wet, so I went to start it again and it went black like it did yesterday. No matter what I did I could not get it to start back up. I thought initially it was a fuse but since it powered up for a minute this morning, I am confused. Anyone ever had this problem or know of a solution. Super frustrating!
Ok, so we had a storm come thru the night before this started. I thought maybe the vent pipe needed to be cleaned… Also, the ignitor lights and it gets hot for about 2-3 minutes then just cuts off. Any ideas?? I disconnected the vent hose this morning and just tried to run it not connected to the vent pipe and it still did it. I am scratching my head on this one…
It actually ignites just fine… Just cuts off after about 2 minutes. The igniter lights it self up fine and the flame puts out normal heat… Just all the sudden turns it self off after two minutes. Still think its the control board?
I just replaced the heating element in my dryer. It worked great for 4-5 loads. now when I start it it shuts itself off after 2-3 minutes. is this my thermostat? It still runs just not for very long so I don’t know what else to do…please help me!!
If this is the only problem you see and it drys properly then there is nothing wrong. The flame should normally go on and off depends on the temperature inside the dryer. The cycling thermostat reads the temperature and operates the flame.
It looks very strange. Sounds like the problem can be a bad control board as well as a bad console panel. There are no more specific tests described in the Tech sheet to narrow the diagnosis.
If you need the correct part number for the console, post the color of it.
P.S. If you will find later that just one of these two parts fixed the problem and you ordered them from Appliance Parts Pros, you can return the second part. No one other supplier will let you do it.
