Whirlpool Drying not starting
About two months ago the gas dryer would only work when the timer was set to the minutes side. It would not start if we set the timer to the other side (level of dryness.) Then about a month ago it seemed to fix itself and we were able to use both settings on the timer. Three days ago the dryer quit entirely, neither side would get it to go. Then after some poking and twisting of the dials, it started up again for about twenty minutes, and the quit for good. I can hear the timer working, and can feel a little vibration in the top console when it is on, but it does nothing.
I opened it up and took a look around, nothing obvious. I took out the thermal fuse and checked it for continuity, came up solid. Checked the thermometer, also solid. I’m a pc technician so I have some experience here, but not much with Ohmmeter, but I followed your guide and think I’m doing it correctly.
Any thoughts on what could cause this intermittent behavior? What should I check next? I’m not too sure how to go about checking the timer. Like I said, I can hear it clicking away, so it’s getting some juice.
Thanks!
Thanks for the help Gene.
I removed the wires from BK and BU and tested for continuity, but it came up good when the timer was in the "on" position, and "open" (needle didn’t move) when in "off" position.
Is there something else I should test on the timer?
I really appreciate the help.
