Hi,
Our Whirlpool Duet dryer (Model# GEW9250PW1) stopped working and the display is faintly lit with 2 dashes ‘–’
The research in this forum suggests that it can be an issue with the electronic control panel.
I was able to fine two Part Numbers: AP6013208 and AP6013210 and was trying to understand the difference between the two and if replacing this part will address the problem described above. If not, I will check the control board.
https://www.appliancepartspros.com/whirlpool-housing-asm-wpl-wp8558753-ap6013208.html
https://www.appliancepartspros.com/whirlpool-housing-asm-wpl-wp8558756-ap6013210.html
Thank you for your help!
