Hi there,
I have a Whirlpool Duet washer that does not do anything after I press start. However, after about 5 minutes it starts to beep three times and flash the error code E1 F6.
To try to fix this, I cleaned the drainage pipe and also replaced the control board (WPW10491312) while checking all the connectors, however the problem is still the same.
Any help would be appreciated.
