Whirlpool Duet Sport washer F-01 error
Have F-01 error code. Manual says press cancel button twice but one press turns machine off. Help
Follow V111’s instructions. it works. You CCU and relay might be located in different location just like mine was but as long as you follow his solution that works.
https://www.askmehelpdesk.com/appliances/error-code-f-01-whirlpool-duet-washer-250513.html
Follow V111’s instructions. it works. You CCU and relay might be located in different location just like mine was but as long as you follow his solution that works. https://www.askmehelpdesk.com/applia...er-250513.html
