Whirlpool duet washer
I have replaced the Central Control Unit…I powered on washer twice and the third time, it would not power on. I checked all connections again and it still will not power back on. What should I try next?
Hi,
Does it display any error codes?
It does not even power on to display anything.
Remember I had it powered on for 3 times in a row and once I replaced the top cover, it would not power on again. Could it be a defective CCU?
— Begin quote from DJefferson;683197
I had the same exact problem,replaced motor control board ,lower left bottom and unit worked–local teck advised me to do.Spent around $500. for both!!
