when i push the power button the power doesn’t come on. i then remove the front panel and pull the connector out of the cpu. i replace the connector and the power then turns on and the washer functions normally. it might work correctly the next time or not, but eventually i have to do the same thing again. no error codes exist. in doing a diagnostic test everything is normal. any help would be appreciated
been there, done that…any other suggestions. seems like the controller has to be reset all the time?
I just replaced the user interface, but I am not getting power to the board. Did you find a solution to your problem? I may have the same issue.
