We have a Whirlpool gas dryer (GGQ8858HQ0, Whirlpool Gold Ultimate Care II) that produces little heat in all temperature settings. No burn marks on Thermal Fuse, and both hi limit and operating thermostats on the side of chimany box and the back of the dryer near the fuse are clean as well. Duct and lint chute are clean. With little heat, we have to run the dryer very long cycles to get clothes damp dry.
Gene, thanks for your help. I replaced the coils today. Now, the flame for Medium and Low setting works nicely. Previously, it wasn’t useable.
Still, as soon as I turn to Heavy or Extra Low settings, the flame goes out, even when the dryer is cold. Come to think about it, Heavy setting never worked well when the dryer was new. Now that I have a little more experience, what will my next step be to make the dryer work for 2 other settings?
Make sure the vent line is absolutely clean all the way to the outlet and it’s made in accordance with the Installation instructions. Proper air flow is very important for dryer performance.
Thanks for getting back, Gene. Took the advice from your separate posting, I had cleaned the vent line top to bottom. While the back was open, I vacummed/wiped the inside as well.
From the sound of it, you seem to suggest that maybe the other 2 settings have something to do with the installation. Is that right? I just read the link you sent. Seems all are in compliance with the instruction booklet.
I had the dryer for about 6 years now. Anything on installation side I should look out for? Or any components might be causing problem at the Heavy and Extra Low settings?
