Dryer will spin with no heat. Tested thermal fuse and it is open. temporarily shorted fuse, and unit seems to heat fine. Do I still need to replace the cycling thermostat?
— Begin quote from ipaontap;118719
You definitely need to replace the thermal fuse and would probably be a good idea to replace the cycling stat also.
You also need to check out your venting also, if it’s gotten slow it can cause the thermal to pop.
The part I tested looks like this
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=266127
Sorry link did not work, Part Number is AP3132867
— Begin quote from ipaontap;118739
That is another thermal on the blower. My fault for not asking which one.
Other then that, you probably still ought to replace cycle stat and check the vent.
— Begin quote from Frank / APP Team;118744
Will do. Thanks for your help
