Replaced the coils 2 years ago…working great since…last week wife mentioned that the dryer is not producing any heat…checked the peep hole and see no light at all…
Took the back off of the dryer and checked the Thermal Fuse with the meter…shows OPEN…so that is one part I ordered today…after reading on here that it suggested that the cycle thermostat is replaced at the same time I also ordered that part from the AppliancePartsPros…while I am waiting for the parts I cleaned the dryer out…also took the time to clean the pipe leading to outside…very dirty…believe that may have been the cause of my problem…
Question…I just took out the cycle thermostat and tested it for continuity…I do get numbers when touching the top and bottom contact on the thermostat…I get a OPEN when touching the left and right contact…does this mean the thermostat is in fact bad?
Also if I replace these parts and it still doesn’t produce heat what should the next thing I look at?
MANY THANKS!
ValpoMan
