Dryer Spins And Works Like Normal But No Heat, Vent Is Clear.
You may want to start the troubleshooting from the thermal fuse (#6 on the diagram) which has to be checked for continuity.
If the thermal fuse is open, replace it together with the cycling thermostat.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246643
P.S. What means [QUOTE]…BBBBBBBBBBBBBBB…[/QUOTE]?
— Begin quote from Gene;310723
You may want to start the troubleshooting from the thermal fuse (#6 on the [B]Replacement parts for WHIRLPOOL LGR4634EQ1 | AppliancePartsPros.com which has to be checked for continuity.
The thermal fuse [part]AP3132867[/part]
The cycling thermostat [part]AP3131939[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246643)
P.S. What means ?
Not a thing i didnt know if i was typing in the right spot. thanks
You are welcome. Keep us posted.
