Whirlpool humming sound
I have a Whirlpool Ultimate Care II washer. (Model # LSQ8243HQ0). As the water is filling up, during wash and during rinse - the washer functions properly, but is making a buzzing sound or humming sound (high pitched type sound). During spin cycle, it functions normally without any sound. Any idea what the problem might be and how to repair it?
Thanks!:slight_smile:
Hi,
I would guess you have something caught in the water pump.
During agitate the pump turns a different direction then when itโ€™s pumping out or spinning.
I would remove the pump and take a look inside.
If there is something in the pump you donโ€™t want to leave it as it could end up cutting a hole in the pump. Then you would have a leak.
This video will help show you have to remove the water pump.
Video: How To Replace a Water Pump On A Whirlpool Made Direct Drive Washer
