was replacing the bulb in tub and had housing out. putting housing back in and it arched on drum. now it will not start
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED5200VQ1
First make sure the power to the unit is OK.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
L1 to Neutral is what powers the motor.
If OK
If OK
Do this with the heater off and on.
Thank You Denman!!!
