power cord had short I fixed the cord and now nothing
I had a short where the dryer cord connects to the block i fixed it and now i have nothing.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED5300VW0
Does the drum light work? If not then you still ahve a power problem.
If you do not have any experience working with electrical then it may be best to get a pro in.
Learning while messing with 240 volts is not a good idea.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
