whirlpool quiet partner iii clean light blinks 7 times
Hi-
I have a whirlpool quiet partner iii that will not complete a cycle. The clean light blinks 7 times. I have done the "reset" where you press heated dry/normal/heated dry/normal to make the light stop blinking. That works, but then when I run the next cycle it will shut down part way through and the clean light will blink. I have ran the diagnostic mode and everything looks normal–the sanitized light turns on in the 9th interval indicating that water temperature is indeed above 100 F. Water seems to fill and drain as it should. Any ideas on what is going on??? Thanks!!!
