Whirlpool range/ error #
Error code reads PF , clock works but can’t reset it . None of the touch pads work . I am wondering if the part I need is part # AP3777769 priced at $148.32 .Thanks
Try to unplug the range for a few minutes and then plug it back. Post the results.
Uplugged the range for a few min. , still reads PF …
If the key pad is still not working, the first failure suspect is a bad control panel. There is very small chance for the control board you mentioned to be bad. If you need the correct part number for the control panel, post the color of it.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133106
The range is black , the model # is GW395LEP800
I believe the part # is AP3777769
I can replace it myself as I’m fairly good at repairs, thanks a lot.
The part with the part number AP3777769 is the electronic control or control board (#3 on the [B]diagram.
The part which I believe has to be replaced is the control panel (#1 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133106&diagram_id=28162513)).
I’m assuming the model number is GW395LEPB00 instead of "8".
[RIGHT]I’m still not sure if this is the part I need . I will order it and find out. Are you located in Orange Co.? I’m in Oceanside , might need help through a phone call or what are your rates. Thanks ,Once again the range is black , the model # is GW395LEP800[/RIGHT]
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/147495-whirlpool-range-error.html#ixzz1rwYaZx7n
Sorry, Oceanside is to far away from me. In case if you’ll need any help, post your questions here and I’ll be glad to help you.
