Hi I have a Whirlpool model LA5668xtw1 stylemaster top load washer that is giving me trouble. I just recently had to replace the drive coupling and the rubber bushing because the plastic drive parts broke. I replaced them and it worked fine for a couple of weeks and now I get a loud bang, bang, bang sound when the washer is running in spin mode (but it does spin) and I can reach in the drum and hold the agitator still at the bottom of the drum if I want to. I am not sure if it makes the noise when I it’s just in wash mode, I just didn’t want to fill it with water again to test it, but I sure will if I have to. I pulled off the cover and peeked under the drum and nothing seems obviously broken like it did when the drive pieces broke. Thanks in advance! What are you thinking? Clutch assy at the bottom of the drum? I took off the cover and jumped the door switch and ran it without the cover and it’s not apparent what is wrong. Sounds near the bottom. Here is where I am looking at exploded assemblies - Whirlpool Product Literature Search Results
Thanks-
Scott
