I have a Whirlpool washer (model LSC9355EQQ) that is leaking small amounts of water from the front underside when the machine is in the rinse cycle. I thought it might be loose hose connections at the pump but I checked and it doesn’t seem to be that. I can’t seem to trace where the leakage is coming from. Could the pump housing be cracked and need replacing? Do these usually go bad? Any suggestions?
Related topics
Washer | 2 | 1701 | June 9, 2010 | |
whirlpool washer leaks | 2 | 1785 | March 23, 2012 | |
11027812692 leaking from the front bottom | 1 | 1934 | October 3, 2011 | |
Washer leaks | 2 | 1957 | November 4, 2010 | |
Leking Whirlpool LSQ8243HQ0 | 3 | 2794 | January 26, 2009 |
