whirlpool washer spin problem
Washer spin cycle not working, only works if I manually get tub spinning first. From looking at other posts it sounds like a bad clutch. Going to order clutch kit. Do I have to remove the spanner nut to get the shaft down through the bottom of tub to access the clutch? and if so do I need a special tool?
— Begin quote from ____
… Do I have to remove the spanner nut to get the shaft down through the bottom of tub to access the clutch? and if so do I need a special tool?..
Yes, you do have to remove the spanner nut and the inner tub. It’s better to use a special [Replacement parts for WHIRLPOOL LSN1000KQ0 | AppliancePartsPros.com](http://www.appliancepartspros.com/part_details.aspx?part_id=4503397&pn_=AP3538707"]spanner wrench[/URL].
You may want to check the drive block and th brakes as well.
You can find some useful information in our previous posts: http://forum.appliancepartspros.com/washer-repair/3265-replacing-direct-drive-washer-brake-shoes.html and
http://forum.appliancepartspros.com/washer-repair/373-not-spinning.html
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265335)
