Whirlpool Washer Spin problems
5 year old Whirlpool washer - doesn’t spin fast enough to drain water from clothes. The only time it will do a decent job is if the load is really light.
Had a repair guy by yesterday - for over 100.00 he told me the motor probably needs replacing…but couldn’t or wouldn’t do it then, and didn’t know the cost.
Is it the motor…or a coupling?
Is this something I can do…or should I call them back? I will not pay the initial service fee of 72.00 to walk in the house…but at 25.oo per 15 minutes…it could get pricey.
It is not an old washer but gets lots of use - 4 kids and me.
I just don’t want to pay hundreds of dollars if it makes more sense to buy a new one…but don’t want to do that either.
He didn’t even check the coupler or the motor.
Please help -
thanks
Kim
Thanks so much for the reply. Very thoughtful.
I found the model # LSR8433KQO and serial CM1984095
IT spins now but usually have to take clothes out and spin it several times to get everything dry enough for dryer.
Don’t know how good/not good this guy was - I did already spend 108.00. And they are quoting a new motor for 150.00 and another 75.00 labor.
Is this something I can tackle? What would I need if it was the clutch and brake assembly? Does it sound more like that than a motor problem.
I don’t know what to do - I just don’t want to spend another 250.00!!! It’s crazy -
Thanks for your help!
kim
I think it’s a clutch problem. and if you have a socket set with a 1/2 in & 7/16 socket and a 10-12" extension we can talk you thru it. And you might be able to fix it without parts with some sand paper (to save you money.)<<possiblity!
We are in a very rural area where a lot of people are on a fixed income, so we try to save people as much money as possible.
Nat
Hi Nat,
What a great service you offer. Thank you - looks like I’m living in the wrong neck of the woods. (Fairfield County, CT)
A friend is going to come by with tools Saturday morning. Can you send me instructions to check and repair the clutch?
I’m really grateful for your time and effort and help. I’m sure I speak for all the other folks as well. Thanks.
Kim
Nat, i emailed you directly but wanted to add to this forum since I registered. Our Whirlpool model LA7800XT is not spinning fast enough to drain tub and clothes. Must run spin cycle a couple of times. Unit has gradually gotten worse, used to drain the water from tub but clothes still wet. Any thoughts with this information?
Can you please forward the instructions to me also. I have sent you mail also. The difference is that my serial number is CP3594802
Murali
Hello, An explanation of the motor switch function and operation would be appreciated. This is the connector/switch that is actually on the drive motor itself. Does this switch reverse the motor?
happ racer
Hi Happ
On your model your motor has both start windings and run windings. When the machine first starts the start windings are powered to get the machine going. After the motor is running, the switch will turn off the start windings and the motor will run on the run windings.
If you have a multiple speed motor the motor switch will also be used to select the speed of the motor.
Hope this helps.
I wouldn’t mind a copy of those instructions myself. However, I’m experiencing the same (spin) problem with (whirlpool) model # LSQ8243HQ0. It spins ok with light loads but will not spin enough to get all of the wetness out of the heavier loads. Have to spin it several times to get the job done. I’m pretty handy with DYI stuff so any help would be appreciated.
Send me an email and I will be happy to forward it to you.
Nat
You can go to my sticky above, "replacing direct drive washer brake shoes" for all the info you need for this problem. No way this is a bad motor, the first guy was way off his repair quote.
All the slow spin problems I have seen are due to a worn clutch. Motors rarly run slow and if they do they start smoking, or the bad wiring connection starts burning. Also,washer motors draw more than 1000 watts at startup and if it fails to run, the wattage goes much higher and the internal overload quickly shuts it off. None of these problems had this syptom.
I would like a copy of those instructions myself. However, I’m experiencing the same (spin) problem with (whirlpool) model # LSQ9549LWO. It spins ok with light loads but will not spin enough to get all of the wetness out of the heavier loads. Have to spin it several times to get the job done. I’m pretty handy with DYI stuff so any help would be appreciated.
Just read my sticky I mentioned above. All the info you need is in there.
Rich I do not find the Sticky you mentioned. More information please.
The sticky at the top of the washer repair section "replacing direct drive brake shoes"
— Begin quote from libertyappl;30649
Nat
I also have a top load whirlpool washer with spin problems. It spins, but not fast enough to wring the clothes out like it should, even after 2-3 spin cycles. It takes hours for the dryer to dry them! Can I have a copy of the
repair instuctions? Thanks in advance.
Curtis
You probably have a worn out clutch and bad brake shoes, go to my sticky above, replacing direct drive washer brake shoes.
Kimmberly,
I have had this happen with my whirlpool as well many times. Most likely I would say it is the coupler. It is either cracked or just rounded out. It is the cheapest and easiest fix of all. Please try this first besides it is probably about time to replace it anyway. I have replaced about 4-5 in the pat 10 years due to overloading it and not a real good design on their part.
can you send me instructions also
Nat
can you send me instructions also. thanks
