I have a Whirlpool CAre MAster II, 2 speed direct drive washer that won’t drain. It seems like the motor won’t go into high spin for the water to drain when there the tub is 1/2 full of water (no clothes). When the water level is low, less than 1/3, it goes into high spin and the water drains properly.
Not sure what the problem is to order the right parts.
During normal washing operation, the washer spins but slowly and no water gets spin/drained out. I started to test it by emptying all water and then putting the washer in spin cycle. With no water, it spins normally. I started to manually filled the water up and noticed that at a certain point of filling (approx 1/3) the motor won’t go into a full fast spin. There is a couple of clicking sound as if the motor is trying to get into a fast spinning cycle but fails and will spins slowly, During the slow spin, no water drains out.
