Washer will not drain or spin
i purchased this washer used 5 months ago and has been running great until today. i ran it and a while later i checked back on it and there was water in it but it would not drain. so i did an internet search on this issue and it stated it was either a clogged sewer hose or the water pump. so i diagnosed that it wasn’t the sewer hose (external) and is probably the water pump. but just for giggles i tried running the spin cycle (with the lid closed and the unit plugged in of course) and it would not spin nor run. so i wonder if the motor blew since the water pump is motor driven?? i don’t think it’s the dials or anything as it does fill up with water if i tell it to. ideas? :confused: thanks in advance.
Hi Rob,
The model number you posted does not come up. Verify and repost it, please.
Gene,
Sorry. Correct model number is JVM1860SD002. Thanks. (I plugged in a couple times over the weekend and it worked for one cycle…it would then restart automatically again) Strange.
