Washer motor running but not spinning
1 out of 3 times that I use my washer it does not work correctly. When it gets to the spin cycle it drains the water down to about 2 inches and the motor runs for it to spin but it does not. It spins on the wash cycle but doesnt for the spin cycle even though the motor makes the spinning noise. Thank you for any help.
Take off the cabinet and see if there is something blocking the pump or the drain hoses.
Assuming that it agitates but does not spin, the problem is likely the clutch. (A lot of those recently)
Here is a site that will show you how to check it.
http://repair2000.com/wp_clutch.htm
