Ok i recently replaced the clutch assembly on my whirlpool washer. I has been working perfectley for about a month. The new problem i have today is it wont spin. when the dial gets to the spin cycle it does nothing. if i turn it back to the end of the rinse cycle it spins fine. Any help is appreciated.
Frank
Hi.
It sounds like the bad timer. Provide the model number so we can get you the part number.
Simon.
This is the model LSQ9110PW0. thanks for your help
Hi, Frank.
Here is the timer for your washer 3955765
Remember that you can return it if it’s not going to solve the problem.
Here are breakdown diagrams and http://www.appliancepartspros.com/controls-rear-panel-parts-for-whirlpool-lsq9110pw0.html
Post the results.
Simon.
thank you so much Simon
You are welcome.
Simon.
