Whirlpool Washer WTW5830SW0 fills and agitates but won't spin or drain o
The washer fills and agitates fine. But, when cycle goes to spin, it only makes a loud "grinding" or loud "humming" noise. Will not drain when I manually move the dial to any spin or rinse cycle, just makes the same noise.
I see a lot of threads that it could be the motor or the coupling. Want to know systematic way to approach the task
