Whrilpool SC8900EX only one burner lights
My gas cooktop will only light the front left burner. The other switches had been making the spark igniter click, but no flame. I switched the left and right modules and the left front was still the only one that would light. So it didn’t matter which burner module was there, the front left always works and the others do not. So the spark igniter is working properly and I need to work my way back from here to see what is causing this problem. What is the next thing to check? Thanks for your help.
ScottB
Next, try replacing spark electrode. You can do the same switching technique with it.
Hope this helps,
Dmitriy
I have this same cooktop. On one side I can hear the "clicking" like it is trying to light, continuously, about every 1 second, but not real fast like when I actually am lighting. It does still light though. When I swap the left and right burner modules, the problem still occurs on that same side, so the problem must be in the man cooktop, not the burner module? Any suggestions?
