Wine Cooler not running - popping GFI
I have a EdgeStar CWR461DZ 46 Bottle Built-In Dual Zone Wine Cooler.
in 2015 it started freezing up more than normal. I turned it off then manually defrosted it.
Over the summer while I was away it stopped cooling however the fan was running.
I turned it off for 48 hours and then plugged it back into a GFI outlet. It blew that GFI.
I then plugged it back into the main outlet that is non GFI and it runs the fan but I am not hearing the compressor.
This is a 2012 model. Is it worth trying to repair?
Any ideas on trouble shooting>
