[SIZE=3] [/SIZE]
[SIZE=3]Here’s my model GSD5500G00CC Dishwasher: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209848&diagram_id=21603325#d21603325 [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Unit runs but does not drain water at end. I have read many of the posts regarding this, and think I know what is going on but want to verify before I purchase the parts.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I did take the unit fully apart. No blockage or build up at all in the sump filter (#508), sump inlet (#505), dual pump hose (#332), pump (#325), body valve and check assembly (#560), or drain hose (#462).[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I tested pump #325 and it runs when directly given electricity. Grey rubber/plastic impellor in it is fine. At the end of a cycle when the pump kicks on I can hear some water running down the sink drain after it discharges from the drain pipe. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Per another thread, I looked at the piston and nut (#564) and it appears to move freely up and down. However, if you stick your head in the dishwasher and look down at the piston and nut (#564) when it is in the up position there is a gap about 1/8" visible all the way around it. Is this supposed to seal shut? If so, mine is not. As a test, I stopped the cycle just before the final drain and rigged a plug for the hole from inside the dishwasher. With that hole plugged, all the water drained out just fine. Can I safely conclude this is my issue? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I tried to remove the piston and nut #564 from the inside of the dishwasher and could not. I then tried to remove the body valve and check assembly (#560) from underneath the dishwasher. I could not even after removing the 2 screws holding it on. I also could not pop the plastic cover off the body valve and check assembly (#560). If I need to replace the piston and nut, how in the world do I do this?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Do I also need to purchase the valve body gasket #560?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Thanks much[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3][FONT=Times New Roman][COLOR=Blue]Is this supposed to seal shut?
Yes
[COLOR=Blue]
Can I safely conclude this is my issue? [/COLOR][/FONT][/COLOR][/SIZE]
Sure sounds like it
[SIZE=3]If I need to replace the piston and nut, how in the world do I do this?[/SIZE]
You could try pouring some vinegar into it and leaving it overnight.
Perhaps it is frozen with calcium/soap deposits.
If all else fails you may have to get a wood dowel or something like that and tap on one of the vanes on top to get it loose.
[SIZE=3][FONT=Verdana][SIZE=2][COLOR=Blue]Do I also need to purchase the valve body gasket #560?[/SIZE][FONT=Verdana][SIZE=2]
[/SIZE][/FONT][SIZE=2]I would not purchase anything till you get it out. then you should be able to see what needs replacing. You may have damaged some parts getting it out.[/SIZE]
Note: I believe that the piston and nut assy also holds the body onto the floor of the dishwasher that is why undoing the screws will not release the body. I am not 100% sure about this.
Compliments to you on your post very nice and complete!!!
[/SIZE][/FONT]
[/COLOR][/SIZE][/FONT]
