Won't spin
This unit appears to work except for the spin or agitate cycle. Basically the motor never spins. I can’t see a led flashing and I tried resetting the computer as was outlined in another post. The door switch is good. Is the computer bad? I would be grateful for any help.
Hello. I’m sending you the failure codes for the motor, if there is no blinks the inline fuse most likely is blown , if that is the case, GE recommends you replace the motor also, thank you and good luck !
[part]AP4390012[/part] [part]AP4536552[/part]
