Hi. I’ve recently gone through 3 ERCs on my Amana oven. The first time, the original 8 year old panel threw an F1-1 (temp over range), so I replaced the temp sensor. That worked for about a day, then the ERC started throwing F1-7 errors. I ordered a new ERC, which also gave F1-7 errors (and the oven light didn’t work, and neither did the Oven Timer Cook time button). I cleaned the ribbon cable but it still works intermittently. I called AppliancepartsPros, who very quickly sent out another ERC, but this one won’t work at all, simply throws an F1-7 and won’t light the oven at all.
I took the back off of the oven and checked all the wiring that I could see - there don’t seem to be any broken/cracked/burnt wires that I can see. Do these boards have quality issues from the manufacturer, or is there something else I can test?
thanks!
