dishwasher would not start. when turned on and pressed STRAT button the, the "NORMAL" and "SOAK & SCOUR" ligts turn on but the dishwasher does not start? Any suggestions?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gu2548xtps7
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208572216.pdf
Sounds like you may have a keypad problem.
Also may be the control board
try to run the diagnostics.
Try the below connector cleaning
Check the keypad with a meter as both these buttons use P1-13 see the Page 2 of the tech sheet
Connector Cleaning
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
