There is about 2 inches of dirty water remaining after the complete cycle. I removed the machine and set it up in the garage to diagnose. The drain hose is not clogged. I removed the pump and applied power with a test wire. The pump starts and runs. I removed the pump cover and the impeller is fine. I have not clipped a volt meter to the pump leads yet to see if it’s being energized, but assume it is not. Not a drop comes out of the drain hose, yet it doesn’t overflow. What tells it when to fill/run/drain?
Related topics
| Topic | Replies | Views | Activity | |
| Dishwasher won't drain | 2 | 1301 | December 11, 2010 | |
| Dishwasher not draining | 4 | 2999 | September 4, 2009 | |
| Frigidaire dishwasher won't drain | 12 | 20840 | October 15, 2014 | |
| My Washer Wont Drain | 4 | 1927 | July 23, 2010 | |
| Dishwasher doesn't drain | 1 | 1326 | November 13, 2009 |
