The dryer spins but doesn’t produce heat and all the lights on the front flash from time to time.:mad:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5156927
Here is the tech sheet for this unit
[http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf](http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf"]http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf[/URL]
And a service manual
[URL="http://frigidaireservicetips.com/pdfs/492_AffinityDryerManual.pdf)
Try unplugging the unit for 5 minutes or so to see if it will reset.
Try running the diagnostics.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
