I’ll keep this short because I posted once and no one replied, it’s a combo unit and the dryer acts like it has no power, doesn’t turn or heat up, has new heat element added a few months ago. Does this have a fuse anywhere? the door seems to shut fine and washer works. Thanks for any info and help with this, it’s getting to cold to hang close outside and it makes them smell, I had a doctor ask me to leave before my appointment was over because of that stink! but that’s a whole other story LOL
This could be the door switch, which you need to check out. If not, the machine has fuses which are blown by too much heat (no electrical fuse, it uses your breakers for safety)
This service manual will show you how to get into it and check it out.
