Dryer not drying
At first drying took longer than normal. Now it does not heat at all. The digital display jumps from 1:36 to 1:52 then goes in a circle after a few minutes. Checked breaker and venting both ok. If heating element is bad should the thermostats and the thermistor also be replaced. Or should I call a repair man.
Here is the parts breakdown, includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE2400AYW
I could not find a tech sheet for this unit
The following may help
[http://www.servicematters.com/maytag_library/docs/ITDL-0037-B.pdf](http://www.servicematters.com/maytag_library/docs/16023432.pdf"]http://www.servicematters.com/maytag_library/docs/16023432.pdf[/URL]
http://www.servicematters.com/maytag_library/docs/IDL-0002A-B.pdf
http://www.servicematters.com/maytag_library/docs/TDL-0076A-B.pdf
[URL="http://www.servicematters.com/maytag_library/docs/ITDL-0037-B.pdf)
Did you actually measure the voltage?
I would check them with a meter first.
[COLOR="Blue"]
Or should I call a repair man.[/COLOR]
Depends on how handy you are !!
