This is my first post, so bear with me. I have a Whirlpool gas dryer that I am having a problem with. It is Model No. LF15801W0, serial no. M82421747. It is a push-button gas start model. I dried a couple of loads this morning without a problem. When I put in the last load, I set the timer, and closed the door, and pushed the button to start the dryer, everything went fine for about 5 seconds, then I lost all power. I did not blow a circuit, the outlet for the dryer is good, there is power to it, the latch on the door seems fine. No broken parts that I can see. There is no power at all to the dryer, even the timer dose not work. Any help would be appreciated. Thanks, Chris.
Related topics
Whirlpool Dryer won't start | 6 | 3389 | July 2, 2012 | |
Whirlpool Drying not starting | 1 | 1959 | October 18, 2008 | |
Dryer won't keep running | 1 | 1187 | November 21, 2009 | |
Whirlpool gas dryer won't start. Fuse is good | 9 | 4002 | August 23, 2012 | |
Whirlpool Dryer wont stay running | 10 | 4867 | September 12, 2010 |
