ok so the dryer does not spin… and when the door is open it will continue to emit heat, the element stays on, doesn’t sound like the motor is trying to run at all …
If heat does not come on in air only cycle, then your motor is bad.
http://www.appliancepartspros.com/whirlpool-dryer-drive-motor-279827-ap3094245.html
Eric
