Dryer comes on and turns but won’t heat. I have taken back panel off and cleaned the vent and checked the fan. Please help with the next step.
Thanks in advance
— Begin quote from rwill;122975
dryer comes on and turns but won’t heat. i have taken back panel off and cleaned the vent and checked the fan. please help with the next step.
thanks in advance
let me help you out here. this is a everyday problem with your dryer. unplug the dryer, and take the back off. it will either be the element is broken, or there is a thermal fuse mounted on the top left side of the element housing, it is round and has 2 wires coming to it. or, your breaker is partially tripped. go outside, and flip the dryer breaker off an on a few times, and then see if it heats. if you have any questions, let me know. tom %url%
[LEFT][/LEFT]
[LEFT]The small limit on the top(300F) will blow if the duct is stopped up[/LEFT]
[LEFT]The bottom fuse is its cousin(250F), they are partners in crime. [/LEFT]
[LEFT]When one fails both are bad and both come in a kit. The dryer[/LEFT]
[LEFT]will however run even if these guys are open(bad).[/LEFT]
SublimeMasterJW said:
[LEFT][/LEFT]
There you go, give them pictures. Something other then a link, for these people to figure it out on there own. Guy’s need to take a little more effort here with the help. If I had all day, and no job, I would help them all. http://www.applianceeducator.com
Thanks for the help I just got home from my 10 hr a day job to lool at the responses. So I appreciate the help and sorry I didn’t respond back quick enough for some people.
If you needs us my man, we are here. Tom %url%
