F23 error on Electrolux Icon oven
I am getting a F23 error when trying to use my oven
Please help, what does that mean?
— Begin quote from Gene;193633
What is the complete model number of the oven?
overn Electrolux Icon
Model E30EW75ESS2
Sorry for the delay.
According to the Tech sheet, "F23" error code means "Communication problem with the TST board". Suggested correction is to replace the glass (control) panel. If it would not help, then the controller has to be replaced as well. Not very good advice but it came from the manufacturer and there is no way to test those parts instrumentally in a home environment.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151353
THANK you so much for your help, we will try that.
— Begin quote from denman;194683
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318046223.pdf
Here is a manual I do not know if it specifically covers your unit but it may be close. Note it does take a while to download.
http://frigidaireservicetips.com/pdfs/481_18.pdf
A bit of a long shot but you may want to try the following before ordering parts
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
— Begin quote from Gene;194633
According to the [Replacement parts for E30EW75ESS2 ELECTROLUX/WALL OVEN | AppliancePartsPros.com](ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/318047411.pdf"]Tech sheet[/URL], "F23" error code means "Communication problem with the TST board". Suggested correction is to replace the glass (control) panel. If it would not help, then the controller has to be replaced as well. Not very good advice but it came from the manufacturer and there is no way to test those parts instrumentally in a home environment.
  • The control panel [part]AP3867499[/part]
  • The controller [part]AP3867311[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151353)
Updated information.
I found today that the control panel comes together with the controller as one piece, so the correction is just to replace the control panel assembly.
Not sure why, but yesterday the "normal" cycle time on my GE pdw9980n00ss increased from the typical 60 minutes to 208 according to the display on the top of the door. I attempted to reset the time by cycleing through the cycles, and even killed the power to the unit for over 5 minutes to reset it with no luck.
Any thoughts or comments?
— Begin quote from chuber01056@yahoo.com;389586
Chuber,
Your problem could have been as simple as a low water temperature, sudsing, etc.
Your dishwasher "re programs" itself, while it’s operating based on inputs from the sensors in the circuitry.
Quite often, you can "re progam" the cycle, by running a complete cycle, empty, with no options chosen.
I’ve added some technical information, that should pertain toyour dishwasher.
Good Luck,
[FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]Always run the factory test mode to calibrate when replacing the turbidity sensor, control module
board, and membrane key panel.[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]The factory test mode is the most accurate way to test the turbidity sensor circuit, which contains the control module, wiring, and turbidity sensor. Factory test mode will test the thermistor (used for automatic temperature control) that is contained in the turbidity sensor and will test the transmitter that is contained in the turbidity sensor.
[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Arial-BoldMT][COLOR=#231f20][FONT=Arial-BoldMT][COLOR=#231f20][LEFT]Entering Factory Test Mode[/LEFT]
[/COLOR][/FONT][/COLOR][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]Note:
[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]This mode can only be entered within the first 2 minutes after power-up. After 2 minutes, factory test mode is unavailable.[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
Disconnect power from dishwasher. Wait 10 seconds and connect power to dishwasher. Press the [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Normal[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]and [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Cookware [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]([/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]"Up" [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]and [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]"Down" [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]on Top Control Models) keypads simultaneously for 3 seconds. (This step
must be performed within 2 minutes of power-up.) The control will step through the test cycle for the preset
amount of time. Press [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Delay/Hours [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]to advance to the next step.[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
[FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20] [/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]TEST CYCLE[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]1. All LEDs illuminate for 10 seconds.
2. Vent fan energizes for 5 seconds, then the active vent closes.
3. Detergent module is activated. Water valve energizes for 60 seconds.
4. Main pump is energized. Water valve continues fi lling for an additional 10 seconds.
5. Heater is energized and main pump continues to run for an additional 60 seconds.
6. Dishwasher pauses for 40 seconds. During this time the turbidity sensor, control module board, and
membrane keypad are being calibrated.
a. The control module will beep continuously and the lock icon LED will light if:
  1. The temperature sensor check does not fall between the limits (42°F to 199°F).
  2. The control receives an analog signal outside the expected range for the turbidity sensor.
  3. The EEPROM was not read correctly.
  1. Drain pump energizes for 75 seconds.
  2. The detergent module is energized for 60 seconds and the water valve is energized for 70 seconds.
  3. The heater and main pump are energized for 60 minutes. (Press DELAY/START DELAY/HOURS on some models to advance to the next step before control times out.)
  4. Active vent opens, drain pump is energized for 75 seconds, then active vent closes.[/LEFT]
    [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][LEFT]Note: [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]If the calibration test fails, check the following:
    • Make certain the dishwasher is not located on a non-insulated outer wall where the temperature at the turbidity sensor may be below 42°F.
    • The turbidity sensor may be dirty. Run a rinse only cycle with one cup vinegar or use citric acid crystals
    (WD35X151) to clean the sensor.
    [/LEFT]
    [FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]This dishwasher is programmed with a service mode to aid the technician in troubleshooting the dishwasher.
    Each component may be cycled to detect if it is functioning correctly. Components are cycled by pressing[/LEFT]
    keypads to the right or the left of the [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Start/Reset [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]keypad.
    [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][SIZE=5][COLOR=#ffffff][FONT=GEInspira-Bold][SIZE=5][COLOR=#ffffff][FONT=GEInspira-Bold][SIZE=5][COLOR=#ffffff]Factory Test Mode
    [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira-Bold][COLOR=#231f20][FONT=GEInspira-Bold][COLOR=#231f20][LEFT]PDW9700 Series and PDW9900 Series[/LEFT]
    [/COLOR][/FONT][/COLOR][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][LEFT]To enter service mode, press and hold the [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]"Down" [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]arrow and [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Heated Dry [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]keypads simultaneously for 3[/LEFT]
    seconds. To exit service mode press the [/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20][FONT=GEInspira-Bold][SIZE=3][COLOR=#231f20]Start/Reset [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=3][FONT=GEInspira][SIZE=3][COLOR=#231f20][FONT=GEInspira][SIZE=3][COLOR=#231f20]at any time.[/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
    [FONT=Arial-BoldMT][COLOR=#231f20][FONT=Arial-BoldMT][COLOR=#231f20][LEFT]PAD Description Time[/LEFT]
    [/COLOR][/FONT][/COLOR][/FONT][FONT=ArialMT][SIZE=2][COLOR=#231f20][FONT=ArialMT][SIZE=2][COLOR=#231f20][FONT=ArialMT][SIZE=2][COLOR=#231f20][LEFT]1L Activates/Deactivates Heater and Fan Test times out after 6 minutes.
    2L Not Used
    3L Activates/Deactivates Water Valve and Smart Detergent Dispenser
    Variable
    4L Activates/Deactivates Detergent Cup Variable
    5L Activates/Deactivates Auxiliary Pump Variable
    6L Activates/Deactivates Main Pump and Single Rack Wash Motor (Wax Motor)[/LEFT]
    Variable
Resurrecting this thread, I just had the same "F23 ERR" message on the oven. Turning the power off for 10 minutes reset it.
I, too am having this problem. I have an Electrolux double oven (Model EI30EW45JS3) That is 3 years old. I’m getting an F23 error code on my upper oven. Some aspects of the upper oven still work: (non-convenction) broil, "keep warm" and slow cook and the cleaning modes work. All functions of the Lower oven works fine. Also the lights don’t come on. I have replaced the glass touch panel (part #318280445), the controller (part #316576655) AND the oven relay board (part # 316443950) which has not resolved the problem. I have triple checked all the connections and all wires aand linkages appear to be in good condition. What am I missing? This is very frustrating … if anyone can offer any suggestions I would be grateful. Thanks ks
–Greg
Greg
Very often manufacturers don’t think about people who will fix their products. This situation is very similar.
This "F23" error code means that controller (EOC) failed to communicate with the oven lights control board. Pretty clear? The only thing they forgot is to mention exact location of this control board. It’s not shown on part diagrams and not listed in parts list!
Guess what? I spend more than an hour to find that it is a part of the oven main harness!
So the main wire harness AP5618525
Please let us know how you repair will go.
2020 - some ten years from the original post of this thread - and f023 ERR brought me here and I was able to fix my problem.
This may have been a short-term fix, but pulling the plug (turn off breaker) for a minimum of 2 minutes reset the oven back to its original state.
Thanks to all the contributors!
