clothes get so hot you can hardly touch them .lint screen is clean and the exhaust is not clogged
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=208133
Could be you have a grounded element.
The element sags/breaks and touches the frame, it then runs all the time and the thermostats cannot regulate it.
Unplug the unit.
Remove the wires from the heating elements.
Be sure to mark them so you know where they go.
Measure each element, usually around 10 to15 ohms.
Then measure from each connector to the frame/case, should be infinite ohms (open)
If not you have a grounded element.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
