ge front loader won't spin
My washer will rotate very little and stop. Will not rotate even a quarter of a turn. I replace motor as I wasting the sensor was bad do to only 113 ohms at p9 connection and not 118. I noticed the thermistor wires were broken off. I put female connected on ends and reconnected. Still no rotation. I am at loss if I should replace inverter or control panel. Any help would be greatly appreciated.
I did a little research online and found that there is a defect with the thermistor and there is an infinite open recall on this model. not sure if the defect caused any shorting somewhere or just needs to be repaired.
well I fixed it and it works great.
