Dishwasher won’t drain after a wash cycle but it will drain after a rinse only cycle. Checked for clogs and cleaned screen in the pump. Is it the drain solenoid?
Remove the filter frame (#543 on the diagram). Unscrew and check the piston & nut assembly (#564).
You can find more useful information in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/17125-triton-dishwasher-wont-drain-fully.html
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=209792
Gene,
Thanks for your post. I felt certain that would be it but no luck. I ordered a new piston and nut and installed it and had no change at all. It still drains completely only on a rinse only cycle but not with a wash cycle. Any other ideas.
There are a few indicator lights on the left side. Is any one of them blinking at the end or in the middle of the cycle?
— Begin quote from Gene;235605
Do you mean the lights that indicate the selected cycle? If so, no none of them blink.
