WASHER WILL RUN THROUGH WASHING CYCLE. WHEN IT GOES TO DRAIN
CYCLE IT CUTS OFF. THE MOTOR IS NOT RUNNING & I HAVE CHECKED THE PUMP & DRAIN LINES. I DIDN’T FIND ANYTHING WRONG . COULD IT BE THE TIMER OR CONTROL BOARD:confused:
