How to fix my dryer
:confused: My dryer is not drying anymore. I would like to try and trouble shoot and fix the dryer myself. Any ideas.
http://www.appliancepartspros.com/parts-for-frigidaire-leq2152es0.html
Need more info.
What works and what does not.
Have you checked the power.
If not then I would start there, the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
