I opened my dishwasher and found water in the bottom it slowly drained overnight took out the shopvac and cleaned the rest. I checked and didnt see any upstructions. My main concern is I have no power to the control panel how can i check to make sure power is going to the panel.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=du930pwpq2
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208535431.pdf
Check it with a meter for voltage.
If you have 120 volts in the wall plug or wire nuts, depending on how it is installed. Then remove power from the unit, remove the door’s inner panel and check the thermal fuse (Item 4 in Section 1). Should be 0 ohms if not replace it. Be sure to use the new harness.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
