I just got my part, but the fan turns on, the compresor is not working, I don’t know if I’m doing it right, please call me at (305)763-7147.
Thank you,
Gloria
Thank you,
Gloria
I am sorry but most of the repair people on this forum are volunteers and do not work for PartPros. They have no way of knowing what you ordered .
If you want help, the best way would be to start a thread in the applicable forum. Remember to give the Make and Model Number. Give a description of the original problem, then what part you ordered and what is happening after you replaced the part.
I am sure someone will try to help you out.
The part I purchase was Starting device kit, compressor. Part AP3885181 (8201786), model SP5029193, serial ED5CHQZKT03, the part can’t be install at the compressor because the manufacture change the model, so it doesn’t fit, and can’t be install.
Thank you,
Gloria
Hi Gloria,
The number ED5CHQZKT03 which you posted as the serial number actually is the model number and it does not come up. Verify and repost it, please.
Also the part number 8201786 is for the start device kit, but it has nothing to do with the APP part number AP3885181 you posted. In order to provide most accurate advise we need the correct model number of the refrigerator and the correct part number you ordered.
Dishwasher was not washing well during 2 cycles. Noticed Washarm nut & radial bearing loose in bottom of unit. Radial bearing was slightly melted. What would cause item’s to loosen? Could this be the cause of poor quality? How tight should nut be when retightened? Otherwise washer has worked well for app. 10 years.
A Model Number may help others help you
